Not printing
Jon30b
Not printing
Post by Jon30b »
When I load in a gcode file into EasyPrint 30 and set the COM port and the printer to I3ProB I click Run Job and nothing happens. The printer has the CH340 chip and I have installed the drivers for it.
Re: Not printing
Hi, Can you provide a specific video?
Jon30b
Re: Not printing
Post by Jon30b »
Re: Not printing
Hi, You need to connect the printer and then slice the model.
Jon30b
Re: Not printing
Post by Jon30b »
I connected, clicked slicer, then when it was done I clicked Run Job and still nothing happened.
Re: Not printing
Hi, Have you chosen the correct port to connect?
Can you provide your specific slice video?
Jon30b
Re: Not printing
Post by Jon30b »
I am connecting to COM 3 which matches with the driver installed:
https://drive.google.com/file/d/12-lg-i ... sp=sharing
Video: https://www.youtube.com/watch?v=UOg-EDFN14Q
Re: Not printing
Hi, You need to connect the printer before slicing.
After connecting, you can see the hot end
and hotbed temperature status of the printer at the bottom.
Jon30b
Re: Not printing
Post by Jon30b »
I have tried this and still nothing is printing. The extruder is staying on 25.9°C and the off bed is staying on 49.6/50°C.
Re: Not printing
Hi,Are you setting up the printer?
Set the print temperature in the extruder and hot bed in the consumables?
