Reflashing firmware
Neil
Reflashing firmware
Post by Neil »
Ok so 2 years down the line my I3 pro B is nothing but a fancy paper weight its had issues since I built the damn thing but here goes with the latest lot
I need to re flash the firmware to the board.
Now i have a new computer so i downloaded the Arduino IDE and the firmware from geeetech.
So loading the INO file only loads the first page of script and leading each page of script results in the program not compiling properly.
Someone please help me out before I set fire to this printer and fix it permanently.
Re: Reflashing firmware
Hi,if you use Arduino, you can refer to this:http://www.geeetech.com/forum/viewtopic ... 20&t=17046
http://www.geeetech.com/forum/viewtopic ... 20&t=17181
I hope this can help you.
Neil
Post by Neil »
Thank you for the reply, I have flashed the firmware in the past, I've used the same cosd from geeetech and various Arduino IDE to do so, now all I get is a non compiling error. And I dont understand why.
I am at the point where I'm actually tempted to scrap this machine for parts. 2 years of problems have really shook my faith in geeetech printers and despite it being an expense I cant afford I am looking to go elsewhere for a machine.
Hi, If you can't use marlin firmware,
You can try to download the still compiled HEX format firmware on the official website.
you can refer to this;https://www.geeetech.com/download.html?download_id=34
Connect the printer to the firmware update via CURA slicing software.
You can use the settings-printer-manger printer
To update the firmware.
Neil
Post by Neil »
well it appear I can't run Cura because of my graphics card- why its a problem I have no idea because I run repetier host andslic3eras well as other programs without issues.
so where do I go now to fix this infernal machine
You can try not to download the latest version of cura to see if it works.
Neil
Post by Neil »
ok so after a new graphics card software and a lot of swearing I now have cura running, however when I got to update firmware it only gives me the option of using custom firmware which I do not know how to do on this program
any advice?
many thanks
Hi, If you can't use cura,
The version using Arduino should be version 1.0.1,
According to your own motherboard type
Download the appropriate firmware: http://www.geeetech.com/forum/viewtopic ... 20&t=17046
Can you provide a specific video?
So that we can solve the problem better.
Neil
Post by Neil »
ok thank you
I have successfully got the Arduino loader but now I have compiling errors that I have never had and I'm not sure how to fix.
In file included from /SdVolume.h:29,
from /SdBaseFile.h:31,
from /SdFile.h:27,
from Marlin.cpp:64:
/Sd2Card.h:32:20: error: SdInfo.h: No such file or directory
In file included from Marlin.cpp:33:
/Configuration.h:497: error: expected unqualified-id before numeric constant
any clues how to fix these?
Hi, Do you refer to this for your operation: http://www.geeetech.com/forum/viewtopic ... 20&t=17181
Can you provide your specific operation,
Or a more detailed picture of this error,
