Reflashing firmware
Re: Reflashing firmware
OK here goes, I now have a working Arduino program that will load the Geeetech firmware, when I go to compile to software before loading it comes back with error code that so far I have never seen in the software and I now need to know how to repair the code to get it loaded on to the board.
the faulty code highlighted is as - bool readCID(cid_t* cid) {
I have never see this error code before and do not know how to fix it to continue with compiling
aloe the message for the error reads Cid_t has not been declared
any thoughts?
any thoughts?
Hi, you can refer to this: http://www.geeetech.com/forum/viewtopic ... 20&t=17046
use Arduino 1.0.1
and refer to this:http://www.geeetech.com/forum/viewtopic ... 20&t=17181
about this error, can you provide more information or
specific related videos?
use Arduino 1.0.1
OK I really don't know what more I can tell you about this problem because we are going in circles and not finding an explanation, so here goes with a step by step of what I am doing.
I load Arduino 1.0.1 and select tools
I check the board is the correct one and make sure the serial pot is connected
I open the INO file that I downloaded form the links you provided me with
I hit compile and load and come up with the same error which reads - "cid_t* has not been declared"
the full error list is -
I have used this file in the past and had little to no problems with it before so why is this issued coming up now?
looking at the error of - /Sd2Card.h:32:20: error: SdInfo.h: No such file or directory
In file included from Marlin__I3_pro_B.cpp:33: - leads me to think that marlin is missing a page of code, however looking through marlin there is no file on there to add in to the program.
I do not have enough experience with coding to change this to a working value and google searches no not provide and answer, and even the Arduino forum is no help as no one has cared to answer my post.
Does anyone understand coding enough to help me solve this problem?
Code: Select all
In file included from /SdVolume.h:29,
from /SdBaseFile.h:31,
from /SdFile.h:27,
from Marlin__I3_pro_B.cpp:64:
/Configuration.h:497: error: expected unqualified-id before numeric constant
from /SdFile.h:27,
Sd2Card.h:191: error: 'cid_t' has not been declared
Sd2Card.h:202: error: 'csd_t' has not been declared
In file included from /SdFile.h:27,
SdBaseFile.h:198: error: 'fpos_t' has not been declared
SdBaseFile.h:202: error: 'fpos_t' has not been declared
now the problem pice of code seems to be -
//return readRegister(CMD10, cid);
I've actually solved to problem I initially had by finding another version of marlin and putting the page of code back in,
next set of issued to d4eal with now
ill keep you posed
ill keep you posed
Ok so today's issue -
The new error codes are
now I am using Arduino 1.0.1 and I have found the file that needs correcting but I do not understand coding well enough to do so.
the code is -
Dose anyone know how to correct this? I am toatlly stuck and need some guidance
many thanks
Code: Select all
core.a(main.cpp.o): In function `main':
C:\Users\HOUSE of ATKINSON\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino/main.cpp:5: undefined reference to `setup'
C:\Users\HOUSE of ATKINSON\Desktop\arduino-1.0.1-windows\arduino-1.0.1\hardware\arduino\cores\arduino/main.cpp:15: undefined reference to `loop'
the code is -
Code: Select all
#include <Arduino.h>
int main(void)
init();
#if defined(USBCON)
USBDevice.attach();
#endif
setup();
for (; {
loop();
if (serialEventRun) serialEventRun();
return 0;
many thanks
Well today's issue and new error codes
On compiling i get this -
the code is -
Dose anyone know how to correct this? I am toatlly stuck and need som guidance
many thanks
Code: Select all
the code is -
Code: Select all
int main(void)
init();
#if defined(USBCON)
USBDevice.attach();
#endif
setup();
for (; {
loop();
return 0;
many thanks
Hi,I find this: https://forum.arduino.cc/index.php?topic=500356.0
I hope this can help you.
