Is there any wat to upgrade my A10 to an A10M?
What do I need?
Thanks a lot in advance.
Regards
Federico.-
Upgrate A10 to A10M
Re: Upgrate A10 to A10M
Geeetech sells whole kit
A10 Slic3r profile: here
Do you know any link?
Because I can´t find it.
Thanks.
Thanks.
Bernardcollin
I bought and received the kit from A10 to A10M
this is definitely not for the beginner...
there is no real user guide included, only 2 diagrams for the mechanical parts, which you can figure out, then you have a picture of the main board and you need to set things on it, not sure if you need soldering, there is a sticker, not sure what to do with it, there is a printer chip not sure where to connect it, there is no wiring diagram, this is so poor I feel like trashing it in the bin
Has anyone successfully upgraded that could help a bit because this is so frustrating, so much money wasted
b
b
Bernardcollin
hi, thanks for your reply
I have the V3.1 board, it has the part soldered already
now I have a cable with 4 additional plus I don't know where to connect, there is no wiring diagram...
2 are marked 3DT, 1 has E1 and E0
ALso the part A4988 not sure what to do with it...![Image]()
- IMG_4890.jpg (181.07 KiB) Viewed 7616 times
- IMG_4891.jpg (331.89 KiB) Viewed 7616 times
Bernardcollin
ok, I found where the 4 plugs were going, in fact I had to remove some with the previous cable and I had not seen it
last problem is the 4988 part which I do not install, maybe it is not needed as I have a more recent board
Bernardcollin
my experience with it for mechanical and connection part
https://3dprinting.odoo.com/mechanical
https://3dprinting.odoo.com/hot-end-assembly
