New A20M Model ?
theju
New A20M Model ?
Post by theju »
I've just buy a new A20M and found some difference between mine and the one show in webpages or in this forum.
Is this a new version or did I buy a clone / counterfeiting ?
  • My extruder Extension Board is not the same, I've free ports not documented and I burn my bltouch :-(
  • My printer is closed under, all photos I've seen have an open frame guivindirect acces to the controle board.
  • The more problematic : The X carriage have an ear, so the hotend doesn't go outside the bed anymore. I can't add a purge bucket for multicolor print.
Is there a spare part to change the carriage ?
Ju
DzzD
Re: New A20M Model ?
Post by DzzD »
I recently bought an A20m too, and notice some differences from what I have read and see on it on internet/youtube :
- no superplate but a sticker bed
- unable to use purge bucket
- fan duct is also maybe smaller
For the purge bucket I simply cut the part that was disabling x carriage to go outside (see picture), you have to be carefull with the x stop, It has worked for me and I am able to use purge bucket now.
theju
Post by theju »
vert wrote: Mon Nov 04, 2019 7:03 pm there are dozens of variations of each geeetech printer in the wild they make changes over time.
OK, but it is not reported to firmware configuration variant ?
For the example of the X "ear", firmware is always reported a -10 mm position at X endstop in official sources, mo mentions of this version in comments.
I'll try to cut 10 mm of the X part.
thanks !
DzzD
Post by DzzD »
If you dont have have tools to do that, you can maybe simply order a new hotend cover https://fr.aliexpress.com/item/32963363300.html
theju
Post by theju »
Thank you for your ansmers, I've finaly cut the piece, all is OK.
I've received a new BLtouch and installed it.
But I'm unable to upload the firmware. I'm facing the timout error :
Code: Select all
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: ser_send(): write error: sorry no info avail
avrdude: stk500_send(): failed to send command to serial port
avrdude: ser_recv(): read error: Descripteur non valide
avrdude: stk500v2_getsync(): timeout communicating with programmer
I've tryed with arduino 1.6.5 and 1.6.10 -> same error
I've tryed with several USB cables -> same error
I've tryed to modify the mega.menu.cpu.atmega2560.upload.speed to 57600 -> same error
I used to have problems to flash my other printers and decide to open the priter to uplod with my USBAsp adapter.
And surprise, no connectors, it seems to be a new bord, marked as GT2560 v3.1
20191104_220859 (1).jpg (157.04 KiB) Viewed 48595 times
If any of you as an idea or links, let me know !
Thank you in advance.
Ju
theju
Post by theju »
Hi Vert,
Good idea ! I had install the drivers manually...
I ask windows to auto update driver, reboot and flash is complete with arduino 1.6.8 !
Last question to go further, did someone know wich drivers are installed to my card ?
Regards,
Ju
theju
Post by theju »
yes stepper drivers.
I've seen nothing on them. It is for selecting in your Marlin 2 config.
Ju
psxsnake
Post by psxsnake »
I have same model variation.
Where you connect bltouch?
theju
Post by theju »
psxsnake wrote: Wed Nov 06, 2019 4:34 am I have same model variation.
You have the 5 pins at the top of the small board, just under the big connector
Ju
theju
Post by theju »
theju wrote: Thu Nov 07, 2019 3:37 am
Ju
Here the photo much easier to understand.
Does anybody know what is the 3 poles connector under ?
Ju
