Full Graphic Smart Controller, with Megatronics
scottmaher
Post by scottmaher »
Is it possible to get Megatronics working with the Reprapdiscount Full Graphic Smart Controller?
http://www.reprapdiscount.com/home/34-f ... oller.html
I have the adaptor you make to work with your smart controller and they are very similar. It would help a lot if the silkscreen on Megatronics had more info around the headers if only marking PIN1 of any given header.
Difficult to use a pinout when you don't know the pins.
Thanks for any help
techsupport
Re: Full Graphic Smart Controller, with Megatronics
Post by techsupport »
Yes, it can work with Reprapdiscount Full Graphic Smart Controller. You need to connect them by jumper wires.
Thanks for your suggestion about silkscreen, we'll taking it into consideration. :)
Have a nice day!
Email: forum@geeetech.com
steeve_becker
Post by steeve_becker »
I know megatronics V2.0 is obsolete ...
anyway I got one and a LCD, I spent time to make its working with Repetier last version,
now it works, please forget the smart connector and use your own wires like this :
Wiring for 12864 reprap Full grafic LCD on megatronics V2.0 and V3.0
Capture d’écran 2019-12-09 à 16.42.46.png (393.35 KiB) Viewed 108721 times
