I3 PRO B Display not working
Klassr
Post by Klassr »
Hello, I've assembled my new I3 Pro B within the last days. After finally switching it on only the fans are working and a green light is on. The LCD display did not show anything. The type of the LCD is different than mentioned in the PDF assebly ionstruction. I've attached two pictures showing assembly of the flat cable on the LCD connector and the controller board.
Not sure if I missed something or maybe used the wrong connector.
Maybe anybody can guide me the right way
Klassr
Re: I3 PRO B Display not working
Post by Klassr »
Added pictures
:D Hi, You can check if your screen wiring is reversed.
Adjust the voltage range you need before turning on the printer;
Turn on the printer to see if three lights on the motherboard are on.
You can refer to:
A+ 三灯亮起的位置.jpg (1.43 MiB) Viewed 46062 times
Klassr
Post by Klassr »
Hello William,
Ve and VB are on, 5V is off.
Do you have a pin layout for the wiring? I checked pin 1 and 2. Looks like Pin 1 is power and Pin 2 is Ground in both connectors. but verifýing would be easier with a proper pin layout.
Reimund
:D Hi, for the schematic you can refer to this: https://www.geeetech.com/download.html?download_id=43
If the 5v light on the motherboard is off, the screen will not light up properly.
Klassr
Post by Klassr »
William, and now? Who is taking care about any next step? Who shall I contact for replacement? This is a new device, I do not want to just buy a new Controller board on my own.
Best regards
Reimund
:D Hi,You can provide your purchase method, country,
Order number and email, we will help you.
Klassr
Post by Klassr »
Hello William,
thank you very much
Order number is: 304-3732564-9113100 (via Amazon)
mail address: reimund.klass@t-online.de
Country is Germany
Home address would be available in my profile or to be sent by mail
Reimund
:D Hi, I have reported the situation to my colleagues,
Will contact you.
Klassr
Post by Klassr »
Thank you very much. Very well appreciated
Reimund
