E180-CURA
E180-CURA
Hi, guys!
Happy Chinese new year!
Today I want to share one of my own Cura profile for E180
1.Print area setting
2.More details
3.Download it and then import it
E180-CURA.rar
(1.2 KiB) Downloaded 1804 times
You can fine-tune according to the actual situation
Welcome to any suggestion
howchoo
Re: E180-CURA
Post by howchoo »
Hi there,
I'm having trouble printing using this profile/settings. I imported and verified them exactly, but my prints all have strange line spacing on both the top and bottom layers. See photo below.
The sides print fine, it's the top and bottom that seem to be underextruding or something.
https://i.imgur.com/JjCBafM.jpg
https://i.imgur.com/tBsjrO7.jpg
I tried:
- Using 3 different spools of PLA
- Changing out the extruder for the spare that came with the printer
- Printing 5 different models
- Leveling the bed a dozen times, it's perfectly level
- Tried different temperatures
- Tried increasing flow rate slightly (though this isn't a good solution, more a bandaid) -- didn't work anyways
It seems like it must be a software issue with these settings. Which settings do you recommend fixing?
Re: E180-CURA
Maybe you can change the value of top/bottom layers and then try it again
howchoo
Re: E180-CURA
Post by howchoo »
William,
I tried using both 5 and 10 layers for top/bottom, same issue. Believe me when I say I've tried everything.
Can you try printing something using the profile/settings you uploaded? And see if it has the same issue. I think this is a software issue.
Thanks,
Zach
howchoo
Re: E180-CURA
Post by howchoo »
William,
Any updates here? Thanks
jamescielen@gmail.com
Re: E180-CURA
Post by jamescielen@gmail.com »
Does anyone have new profile info for Cura Geeetech E180?
chicgeekstudios
Re: E180-CURA
Post by chicgeekstudios »
Does anyone have a Cura profile for the E180? The .rar file posted in the thread above does not unpack. It gives an error every time I try to unpack it and I have tried several different rar opener softwares. TIA
Re: E180-CURA
Hi, you can provide your email, and I will send it to you.
D-a-n
Re: E180-CURA
Post by D-a-n »
Hello!
Please update the profile for the new version Cura this config is not suitable!
Thank
_________________________________
My working config for Slic3r-1.3.0.64bit:
https://www.geeetech.com/forum/viewtopi ... 00#p103700
scannon34
Re: E180-CURA
Post by scannon34 »
Can you please post or send me the updated E-180 Cura profile?
