Cura profile for Geeetech A20
Hi guys! :o
Are you can't find Geeetech A20 on Cura?
Don't worry
Refer to these:
------------------------------ :D --------------------------------------------------
Update:Thanks for @vert's suggestions.
1. We added the G29 for the start code
We added the "G1 Y230 F6000" for the end code( 2019/1/7)
2. We attached the PLA filament profile for Multi_mixer printer(2019/1/23)
3. We set the default filament diameter to 1.75mm and it can work with Cura 4.0(2019/4/7)
4.Thanks for @LisaE‘s suggestions.The profile updated.(2019.4.17)
5. Deleted the "Heating gcode for nozzle/hotbed"in"start code".Added the meshes file.(2019.4.24)
1.Download Profile for Geeetech 3Dprinter
Cura4.0 resources.zip
(158.48 KiB) Downloaded 2664 times
Download the PLA filament profile for A10M
Geeetech-pla.xml.zip
(932 Bytes) Downloaded 1840 times
2. Unzip the zip file then you will get "resources"folder
3.Copy "resources" to the
Cura installation directory
Default:
C:\Program Files\Ultimaker Cura 4.0
3.Import the PLA filament profile for Geeetech A10M
4.Done!Enjoy it!
Time
Re: Cura profile for Geeetech A20
Post by Time »
hi Guys
what I have to do when using cura for mac?
JuMe
Post by JuMe »
Jetzt ist die Cura 4.5 da. Gibt es inzwischen neue Setting für den A20M? Ich meine, die bisherigen sind veraltet und es gibt sicher neue Erkenntnisse.
Now the Cura 4.5 is here. Are there new settings for the A20M in the meantime? I mean, the previous ones are outdated and there are certainly new findings.
