Installing 3D Touch on A30
Post by 156801 »
just upgraded from Geeetech I3 ProB to a A30 and a good move. I want to instal a 3D Touch which I thought would be plug and play, but do research it does not seem that straight forward.
To install I need to
1. Remove 3 pin socket and install 5 pins see pic's
Extruder Top.jpg (84.51 KiB) Viewed 7010 times
Extruder bottom.jpg (107.21 KiB) Viewed 7010 times
2. Flash firmware with A30_3Dtouch_V3.zip
3. update the UI for LCD after upload the firmware
A30 Refer to this post:
viewtopic ... 65&t=60740
Questions
a, Is this all that is necessary to install the 3D Touch?
b, What way do the wires go on the 5 pins ( Colour left to right )?
c, What type of board is this - ref image
Looking forward to your help.
Robert
Re: Installing 3D Touch on A30
Hi,Your adapter board is an adapter board for capacitive sensors.
and the new motherboard is GT32 pro vd.
the old is GT32 mini.
156801
Post by 156801 »
Thank you for the reply William.
So the board will be ok for the touch sensor when I solder the 5 pins in?
Robert
Hi,You need to use the corresponding adapter board, your adapter board should use capacitive sensors.
156801
Post by 156801 »
Hi William do you have the part number Or link for the board that I need for the touch sensor so I cab buy it from your shop?
