Hello, friends!
Assembling Geeetech I3 Pro C
Is it correct that the acrylic Y motor fix plate is installed as shown in the pictures? Or should the angle between the Y motor fix plate engine board and acrylic plate (rear) be 90°? To get 90°, the ends of the bar must be leveled with a file. Is it necessary to do this?
Geeetech I3 Pro C. The angle between the Y motor fix plate and acrylic plate (rear)
- IMG_20200325_090418.jpg (244.59 KiB) Viewed 27241 times
- IMG_20200325_090554.jpg (261.25 KiB) Viewed 27241 times
- IMG_20200325_090033.jpg (252.33 KiB) Viewed 27241 times
Re: Geeetech I3 Pro C. The angle between the Y motor fix plate and acrylic plate (rear)
Hi, you can view the assembly manual:
Thanks. But the archive does not open, the format is incorrect or damaged
