Geeetech I3 Pro C. The angle between the Y motor fix plate and acrylic plate (rear)
vvplock
Post by vvplock »
Hello, friends!
Assembling Geeetech I3 Pro C
Is it correct that the acrylic Y motor fix plate is installed as shown in the pictures? Or should the angle between the Y motor fix plate engine board and acrylic plate (rear) be 90°? To get 90°, the ends of the bar must be leveled with a file. Is it necessary to do this?
Re: Geeetech I3 Pro C. The angle between the Y motor fix plate and acrylic plate (rear)
Hi, you can view the assembly manual:
金属版pro C building_instruction .rar
(19.87 MiB) Downloaded 950 times
vvplock
Post by vvplock »
Thanks. But the archive does not open, the format is incorrect or damaged
