Edge not 100% straight
novawaves
Post by novawaves »
hi
after i printed a calibration cube i see that the z edges of the cube are note 100% straight.
i looks likes a liite zig zag but only very very little zig zag. is there a solution for this?
is the temperature to high so that the pla dissolves unter the presure of the above layers? what do you mean?
here is a example of the printed object
Re: Edge not 100% straight
Hi, You can see if the z-axis threaded rod is bent
Check if the z-axis fixing plate is loose,
Tighten if loose.
novawaves
Post by novawaves »
hi
now i have disassembled my rod and stepper motor
in the video you can see that the attachment of the rod is not in center
https://youtu.be/UcZLsw5gh54
i try different methods to center it but without success
do you have a solition for my problem?
thx
Hi,do you mean the position of the coupling
You can adjust it with tools,
You need to see if the z-axis threaded rod is bent,
Whether the z-axis fixing plate is loose,
Because the ripple may be caused by the z-axis shaking.
novawaves
Post by novawaves »
the rod is a little bit bend and i correct it a little.
but the couple on the video is also not in center therefore i think it is a problem because it shake the rod or isnt it?
can you please descripe how to center it correct
thx
