Prusa i3 pro B print quality issues
harrynice
Post by harrynice »
Hi all,
I am having loads of trouble trying to get my printer to calibrate and print properly, resulting in the prints you see in the attached picture (yellow was supposed to be a calibration cube, white was a simple disk).
Is anyone able to give an initial diagnosis of what I need to do based on what they can see? I appreciate that this is a broad remit, but am hoping someone can point me in the right direction.
Thanks in advance!
Re: Prusa i3 pro B print quality issues
Hi,you can check whether the step vanule corresponds to the value in the picture below.
harrynice
Post by harrynice »
Thanks - someone on reddit gave the same advice and it worked.
Could the firmware not be updated to correct this?
harrynice
Post by harrynice »
<duplicate post>
BlueCross
Post by BlueCross »
harrynice wrote: Thu Apr 16, 2020 12:16 am Hi all,
Thanks in advance!
My Pasco Connect
I faced similar kind of issue last time, I am still searching for some proper solution Same issue still no fix to this.
Did you have a fix on this issue? I have the same problem with Facing same issue but no response from anyone and couldnt find this topic troubleshooting in google.
BlueCross
Post by BlueCross »
Thanks in advance!
