extruder Extension Board diagram
Re: extruder Extension Board diagram
or >
green - red - yellow
black - white
black - white
- 3d_touch.png (402.79 KiB) Viewed 14727 times
Could you also make a photo with wire colours for the extension board of the A30? I want to connect the 3d touch.
Greetings
Greetings
Hi, you can refer to this:
But how? My extension board looks like the first photos in this thread.
Is it possible that the first photo ist wrong? I thought the capacitive sensor uses only 3 pins (the lower ones) and rhe 3d touch the upper 5 pins? Or am I completely wrong?
Greetings
Greetings
maybe this can help you.
- TIM图片20200415110654.png (124.54 KiB) Viewed 14446 times
Thank you!
Hi,William wrote: Wed Apr 15, 2020 11:06 am Hi,
Do you have the full pinout of this board? I am trying to convert my A10M from 2in1out to a 2in2out, so I need to add a hot end heater and a thermistor. Is this extension board compatible with this modification?
William, i'm interested in the full pinout of the new extension board too!
Thanks in advance)
Thanks in advance)
Maybe it can help you
- .png (456.42 KiB) Viewed 11960 times
