Geeetech A30T Test
Heiko
Geeetech A30T Test
Post by Heiko »
Bonjour
Heiko :roll: :roll: :roll:
Re: Geeetech A30T Test
Hi,if your model is brushed, the possible reasons are:
1. The model is too complicated and the model size is too small. You can reduce sharp corners, thin walls and cantilever structural design through model processing
2. Model cooling is not enough. You can increase the wind power of the cooling model fan.
3. With regard to the drawback parameter set by the model, you can adjust the drawback speed and distance (the drawback distance should not exceed 6mm).
gio@dkonline.be
Post by gio@dkonline.be »
its a stress test
if printer dont print this test a stock here is a big big problem from geeetech conceptor no???
William, do you have a cura profile for this machine?
I contacted all the buyers of the A30T and nobody can make beautiful prints. Everyone has way too many problems.
is it possible that geeetech tests the machine and performs a correction and working profil fora good slicer (cura, prusa slicer)
thanks.
hrhlasvegas
Post by hrhlasvegas »
I have an A30T myself and I had all sorts of problems. Now the printer doesn't even turn on anymore and I am trying to flash the Firmware to see if it reboots. The problem is that THERE IS NO WAY TO FIND THE FIRMWARE online and support is not answering my emails. Can anybody help me?
gio@dkonline.be
download stm32 software and i give you the S19 dumped firmware. just put a jumper on boot pin on mainboard, connect to computer and flash.
and if geeetech dont reply to give a update, i decompil firmware and publish to all.
its a full buged printer
gio@dkonline.be
dumped firmware A30T https://easyupload.io/08d3l5
original stock firmware.bin https://ufile.io/m6oh88sd
software stm32 https://easyupload.io/r0r1y2
Setting of firmware before and after a reset Image
lcd firmware patched with good translation (PUT IN A SD AND PUT IN SD READER OF LCD and power on) https://app.box.com/s/c9suuy8vrcsq60zw5gsr2y13g9sqwrie
Last edited by gio@dkonline.be on Sun May 03, 2020 1:02 am, edited 1 time in total.
hrhlasvegas
Thank you so much! Where do I find a jumper?
If the printer still connects to the computer via USB what do I do?
hrhlasvegas
Also I use a MAC
hrhlasvegas
Also to download the second link I am asked for a password
gio@dkonline.be
