A 30 T & 3 d touch
Klink
A 30 T & 3 d touch
Post by Klink »
Hello
Can you give some indication how correctly plug thez 3 d touch an a A 30 T.
can you send me picture
I try to maque a automatic levilling but When I do that the extruder make a + Z 59.99
I make a vidéo maybe more expressive : https://youtu.be/ci7WgnbmCUI
What wrong ?
regards
Re: A 30 T & 3 d touch
Hi,this is the connection.
Klink
Post by Klink »
Thank you Wiliam for the picture
my cable was plug like you. So what do I wrong ?
if I try to an auto leveling at first position I have a message 3D Touch check failed, please check and try again
I film it https://youtu.be/S2RvBcs4UKY
What can I do ?
gio@dkonline.be
Post by gio@dkonline.be »
hi
dont use 3D touch, not work with actual firmware
dont give 2X same value
Z never good 2X
sorry,the link cant be opened,you can upload the compressed file here.
Did you modify firmware?
Klink
Post by Klink »
Hello William
I can't attached the video it's to big. I upload it on my server : https://lkpc.fr/17
I don't touch the firmware. I beginner in 3 D print.
Sorry I still can't open the link. 3dtouch needs to be set up to use firmware. You can refer to this manual.
3DTouch auto leveling sensor User Manual.rar
(1.43 MiB) Downloaded 377 times
gio@dkonline.be
have you a firmware fix for 3D touch now for A30T?
firmware 1.01 dont give 2X same value with 3D touch
only proxy sensor work a little better
same error for all A30T user
