The TMC2208 about A20T Firmware
Admin
Post by Admin »
:D Hi,Guys.
the firmware about the A20T TMC2208
you can download from this link :
A20T_TMC2208.rar
(121.39 KiB) Downloaded 1481 times
giogio
Re: The TMC2208 about A20T Firmware
Post by giogio »
HI i need same for A30T please
have you the uncompiled firmware please?
thanks
Hi, thanks for your feedback.
now the firmware is being tested.
mlabis
Post by mlabis »
Hi friends, is there A20T firmware with 3D touch and TMC2208 support?
mlabis wrote: Sun May 03, 2020 3:56 am Hi friends, is there A20T firmware with 3D touch and TMC2208 support?
Hi,we do not have the corresponding firmware, you can directly exchange the wire sequence as shown in the figure.
Bobertino
Post by Bobertino »
I would like to upgrade to TMC2208, but have BlTouch.
Are you saying that if we swap the wires it will be supported?
Do you know when we will have a firmware with TMC2208 and 3DTouch support?
Hi,the firmware has nothing to do with the driver, you can still use the firmware that supports 3Dtouch.
Bobertino
Post by Bobertino »
I have installed TMC2209 https://www.amazon.co.uk/dp/B082FBLH62/ ... _at_prodpg
I'm trying to tune the VREF and all I get is 4.88v. Potentiometer makes no difference on output.
I know it could be a defective product, but I would be surprised if 5 of them are defective.
Any suggestions on what might be the problem?
Hi,can't adjust the voltage?
Bobertino
Post by Bobertino »
Correct. I can't adjust the voltage.
My guess is that the VREF pin hasn't been wired correctly, I found someone else with the same problem.
They probably work fine, but I have no way to adjust them without the VREF pin working.
I'm going to return them and get a different brand.
