How to fix-E180>The screen displayed not correct or black screen
Re: How to fix-E180>The screen displayed not correct or black screen
I found jtag pinout and connected the lcd via st- link. But I dont have flashing file to upload. Geeetech technical said me:Metal head: v2.02
Ceramic head: 1.32.41
The two versions are incompatible
Update the corresponding version. So I installed the wrong update.
- 40A507D2-2224-413E-A0EC-01269754F083.jpeg (670.76 KiB) Viewed 49341 times
Lcd jtag connection pinout. For flash with st-link v2.
- B3632128-865D-4739-8D1C-F81E139C4714.jpeg (665.83 KiB) Viewed 49338 times
maybe you need this:
Motherboard application: E180_M04_V2_02.bin
Motherboard boot program: MotherBoot_bootloader_V1.0.bin
LCD screen application: E180_S01_V2_02.bin
LCD screen boot program: LCD_E180_bootloader_V2.0.hex
The SD card needs to be formatted before use, as shown in the attached picture. Note that when unplugging and inserting the SD card on the computer, the SD card needs to be ejected first and then removed.
The motherboard boot uses the "Flash Loader Demo" programming tool for programming, and the motherboard application uses the "firmware_tool_V2.0" programming tool for programming and must be the firmware_tool tool of version V2.0 or later.
The screen guide uses the ST-LINK emulator for burning, and the firmware is LCD_E180_bootloader_V2.0.hex; the application uses the "firmware_tool_V2.0" burning tool for burning, and the file is E180_S01_V2_02.bin, or the ST-LINK When recording, fill in the address as 0x08010000.
When the firmware is burned, the boot file is burned first, and then the application file is burned.
Everything was so beautiful. I did the narratives step by step and my lcd screen and motherboard were seamlessly updated to v2.02. Thank you very much to my friend William for their help.
Sorry Mustye180, I wasn't on forum two months.
William - can You explain what is different V1 and V2 - I flashed my printer V2(metal hotend) flash from V1(ceramic hotend), and It working perfect.
On the information screen shows V1.6-null.
Now on download section the V2 firmware is enable, a little to late.
Regards
Regards
Sorry I can't view the picture, can I upload it again?
Hello. Where i can find "firmware_tool_V2.0"?William wrote: Wed May 20, 2020 10:41 am maybe you need this:E180-V2.02.02版-去掉密码.rar
My printer is not working after trying to upgrade the firmware.
My LCD board is like show @Mustye180.
Yesterday before upgrading the firmware with EasyPrint, i had v2 firmware. My printer have metal hotend, it seems like MK8.
Please help me to upload correct firmware.
Thank You.
I made it. My printer works like before.
frimware_tool_v2.0 i found here -> https://www.geeetech.com/download.html?download_id=40
Before i didn't see it becouse there need to click on plus + Firmware Toolkit For Geeetech Printer to see file for windows.
firmware E180-V2.02.02 i had download from here -> https://www.geeetech.com/download.html?download_id=41
Awesome!psqdny wrote: Sun Jun 21, 2020 3:16 pmHello. Where i can find "firmware_tool_V2.0"?William wrote: Wed May 20, 2020 10:41 am maybe you need this:E180-V2.02.02版-去掉密码.rar
Thank You.
Hello
I have a similar problem with the black screen on the E180 printer. I made the system with a memory card and it worked for a while but it probably fell completely. Does screen replacement solve the problem or is it a system problem?
