Broken Parts by delivery
chris76
Post by chris76 »
i have bought a MeCreator 2 over Aliexpress. After i open the parcel i found that the extruder was not secured and so it hits the Y Axis Motor holder with bearing and the Belt holder and its broken.
Unfourtenly the reseller is not responding my request and so i need your help please.
Is there for Germany any Spare Parts available or is it possible to print those parts as PLA or ABS on a other printer?
I will try to put a picture to this post for reference.
Greetings
Re: Broken Parts by delivery
Hi,could you leave your email address and order number?Seller will contact you as soon as possible.
Disconnect
Post by Disconnect »
I have the same issue. Could you tell me, where can I find those parts to buy!?
ar4saratov@gmail.com
Thank you!
ser58
Post by ser58 »
I've received a printer i3 pro B with the following parts broken:
- i3-06
- i3-08
Is it possible to receive the STL files to print them?
Thank you
Maybe you need it?
Pro_B_stl文件.zip
(291.33 KiB) Downloaded 767 times
calabrovarijo
Post by calabrovarijo »
chris76 wrote: Wed Jun 07, 2017 9:39 pm Hi,
i have bought a MeCreator 2 over Aliexpress. After i open the parcel i found that the extruder was not secured and so it hits the Y Axis Motor holder with bearing and the Belt holder and its broken FileZilla UC Browser Rufus.
Greetings
