Serial Port Speed Witz Arduino 1.0.1?
Hello, I've tried to upload new firmware to my I3 Pro B. I've downloaded Arduino 1.0.1 and the actual Firmware. Trying to connect to my printer I've used the serial monitor https://snaptube.cam/. Within this I can't set the required port speed to 250000, so geht no connections and can't Download actual configuration data. With the newest version of Arduino this works fine and I get the configuration info downloaded. But using this I get compilation errors. Any suggestions.
Re: Serial Port Speed Witz Arduino 1.0.1?
To compile newer firmware versions you got to use Arduino IDE 1.8.x.
Otherwise I recommend you try VSCode for this.
Check out my little tutorial here, https://github.com/jonsag/Marlin-3D-Pri ... loading.md
In my repo you can also get my configs and other things.
https://github.com/jonsag/Marlin-3D-Printer-Firmware
/jon
/jon
YolandaOwen
Glad to know about the company and they should offer the wise recommendations to the customers. The people who need the business solution for them such services on https://www.wanderingeducators.com/best ... iter-guide are pretty suitable. Nowadays various businesses are online and people earn a handsome amount of money.
