Serial Port Speed Witz Arduino 1.0.1?
Melita01
Post by Melita01 »
Hello, I've tried to upload new firmware to my I3 Pro B. I've downloaded Arduino 1.0.1 and the actual Firmware. Trying to connect to my printer I've used the serial monitor https://snaptube.cam/. Within this I can't set the required port speed to 250000, so geht no connections and can't Download actual configuration data. With the newest version of Arduino this works fine and I get the configuration info downloaded. But using this I get compilation errors. Any suggestions.
jonsag
Re: Serial Port Speed Witz Arduino 1.0.1?
Post by jonsag »
To compile newer firmware versions you got to use Arduino IDE 1.8.x.
Otherwise I recommend you try VSCode for this.
Check out my little tutorial here, https://github.com/jonsag/Marlin-3D-Pri ... loading.md
In my repo you can also get my configs and other things.
https://github.com/jonsag/Marlin-3D-Printer-Firmware
/jon
YolandaOwen
Post by YolandaOwen »
Glad to know about the company and they should offer the wise recommendations to the customers. The people who need the business solution for them such services on https://www.wanderingeducators.com/best ... iter-guide are pretty suitable. Nowadays various businesses are online and people earn a handsome amount of money.
