Problem with geeetech prusa i3 pro c
hotmetal
Post by hotmetal »
hi, the printer works fine i can move the axis and the extruder, lcd is working, etc but, when it start to print, the extruder fail and stop the extrusion, and the lcd is possessed by the Evil, i reinstall the firmware several times and the same thing :(, is my printer dead?
Re: Problem with geeetech prusa i3 pro c
Hi,could you take a video about your actual case as much more detail as possible? It will be more clearer and easier to find the key point.
hotmetal
Post by hotmetal »
I Will post a video, but i think is the board, the extruder stepper driver was burn, and the Y axis nema 17 is toasted, i have replaced both, but the problem persist, and now the y axis is miss aligned, and the motors do not have enought power to move the y-x axis and make a noise like a stuck noise. i will disarm the entire printer and will check the stepper drives again with the multimeter.
Pd: i replace the y axis stripper Drive u.u
https://youtu.be/OmBbXEsKa4U
Maybe you can add some Lubricating oil to the Y-axis to make it move smoothly.If the motors do not have enough power to move the related axis,you can increase the voltage between VDD and GND on the driver board of GT2560,just like the pictures showing.
hotmetal
Post by hotmetal »
thanks william i will try sooner i can, i get a cold and i am very sick now, look those pictures:
i was printing like this before the printer get sick. 0.1mm
then i print a calibration cube 0.2mm
and then everything is going to hell xD, in some point the y axis was not be able to move and printed this
and the lcd D:!!
As to LCD issue,you can click the Reset button under the knob.If it still the same,It should be the firmware issue.
At first,go to LCD menu and click:Control>Restore Failsafe.
If it still the same,just re-upload the latest firmware.I suggest you to upgrade the firmware with EasyPrint 3D.
Here is the download link:
http://www.geeetech.net/firmware/EasyPrint.msi.
And here is the instructional video you can refer to:
https://www.youtube.com/watch?v=U3ua4vM ... pqufTgHOgE.
Hope it can help you.Please let me know the latest situation after that.
hotmetal
Post by hotmetal »
i dont know what happen seems like some Gremlins attacked my printer:
all vref was wrong 0.95 D:!!!!
and my heater was unscrewed :/
i fix that and now my geeetech is printing like a charm :3
no issues with the lcd
thanks a lot william
It's my pleasure to help you,hope you enjoy the printing fun. :D
Hi, Have you tried adjusting the drive board voltage?
Quintana63
Post by Quintana63 »
If you're hiring somebody to try to your online assignment then you'll be able to explore the best service here https://www.uk-dissertation.com/buy-assignment.html which may offer you one thing sensible to be told and confirm you furthermore may create your writing to boost because it takes time to let something wonderful happen
