Sanguinololu driver on Windows 10 not possible to install
DrOetker
Post by DrOetker »
Hi @ all,
I just bought the Geeetech 3D Printer Aluminum I3. Everything is built up and mechanical is everthing fine. But I try to get access to the firmware, because I have to change some values because of wrong direction of the axis. But I have no stable access to my firmware, that means I cannot upoload the firmware to the board.
I think the problem is my driver. When I run Arduino 1.0.1 I have no possibility to choose the Sanguinololu as Board. I have communication with 3D printer with the repetier host software.
Have you got any suggestion, why I cannot choose the Sanguinololu as Board in the Arduiono Software? My PC runs with windows 10
Thanks allot!!!!!!!!!!!
Re: Sanguinololu driver on Windows 10 not possible to install
You need the sanguinologu folder I attached and put them into the hardware folder. Then restart the IDE and select the right board.
sanguino.zip
(209.25 KiB) Downloaded 1093 times
sanguino.zip
You can refer to this post.
viewtopic.php?f=20&t=16433
sonix
Post by sonix »
It is very easy to install drivers in Windows 10. If you still did not find the solution then visit on papercheap.co.ukl as they working fine to find solutions to the different problems.
daniyal11
Post by daniyal11 »
Uttar Pradesh Madhyamika Shiksha Parishad (UPMSP) has released the model papers for UP Intermediate (Class 12) Board Exams 2021. The exam board has released the subject wise model papers for Class 12 board exams of Uttar Pradesh. The model papers of UP Intermediate board exams will help the candidates WBCHSE 12th Blueprint 2021 to have an understanding of actual exam pattern of UP Class 12 Board Exams, nature of questions and weightage of marks for each section in a specific subject. UP Class 12 students must note that the UP Intermediate model papers are just for reference, and the questions in model papers are not asked in the UP Class 12 board exams 2021.
tilmofesta@vusra.com
johny
Post by tilmofesta@vusra.com »
I’m going to read this. I’ll be sure to come back. thanks for sharing. and also This article gives the light in which we can observe the reality. this is very nice one and gives indepth information. thanks for this nice article...Satta king 786
johny
Trends N Best Best Guide For Govt Grants & DonationsHow to get free air conditioner for seniors
Find the best essays on is my friend's profile page.Mountain Biking Tour in Kathmandu
JOHNY
Do you want to hold an estate sale of your own? If that's the case, you may be thinking if you should do it yourself or employ an estate liquidator. We recommend you hire our expert estate liquidator. Using competent Liquidation Services in Boston to downsize, upsize, or relocate your local business will save youOffice Liquidation Services In Boston
SEO
At this point you'll find out what is important, it all gives a url to the appealing page:Ayurvedic Treatment in UK
nancydrewsub
Post by nancydrewsub »
Thank you for the info information, I will wait for posts like this and will read them with pleasure :) wordle 2
