Arduino GPRS Shield SIM900 not working by software
ZiTAL
Post by ZiTAL »
Hi i have an Arduino GPRS Shield SIM900.
The shield works fine with hardware mode (PIN 0,1) but i can't put working with software mode (7/8).
I put the jumpers the right way and doen't works:
Code: Select all
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
void setup()
 mySerial.begin(19200);  // the GPRS baud rate
 powerUp();
 delay(5000);
 sendSms();
 delay(10000);
void powerUp()
 pinMode(9, OUTPUT);
 digitalWrite(9,LOW);
 delay(1000);
 digitalWrite(9,HIGH);
 delay(2000);
 delay(3000);
///SendTextMessage()
///this function is to send a sms message
void sendSms()
 mySerial.print("\r");
 mySerial.print("AT+CMGF=1\r");
 delay(1000);
 mySerial.print("AT+CMGS=\"+34123456789\"\r");
 delay(1000);
 mySerial.print("Arduino SMS Test by soft! \r");//the content of the message
 delay(1000);
 mySerial.print((char)26);//the ASCII code of the ctrl+z is 26
 //mySerial.write(0x1A);
 delay(1000);
void loop()
i changed the jumpers to hardware mode and this code works:
Code: Select all
void setup()
  Serial.begin(19200);  //Baud rate of the GSM/GPRS Module
  powerUp();
  Serial.print("\r");
  delay(1000);
  delay(1000);
  Serial.print("AT+CMGS=\"+34123456789\"\r");    //Number to which you want to send the sms
  delay(1000);
  Serial.print("Arduino SMS hard Test! \r");   //The text of the message to be sent
  delay(1000);
  //Serial.write(0x1A);
  Serial.print("\r");
  delay(1000);
void powerUp()
 pinMode(9, OUTPUT);
 delay(1000);
 delay(2000);
 delay(3000);
void loop()
[code]
The Shield power up with both code.
Watching this wiki:
[url]http://www.geeetech.com/wiki/index.php/Arduino_GPRS_Shield[/url]
i try with this code to work with hyperterminal/minicom:
[code]
//Serial Relay - Arduino will patch a
//serial link between the computer and the GPRS Shield
//at 19200 bps 8-N-1
//Computer is connected to Hardware UART
//GPRS Shield is connected to the Software UART
SoftwareSerial GPRS(7, 8);
unsigned char buffer[64]; // buffer array for data recieve over serial port
int count=0;     // counter for buffer array
void setup()
 GPRS.begin(19200);               // the GPRS baud rate
 Serial.begin(19200);             // the Serial port of Arduino baud rate.
void loop()
 if (GPRS.available())              // if date is comming from softwareserial port ==> data is comming from gprs shield
   while(GPRS.available())          // reading data into char array
     buffer[count++]=GPRS.read();     // writing data into array
     if(count == 64)break;
   Serial.write(buffer,count);            // if no data transmission ends, write buffer to hardware serial port
   clearBufferArray();              // call clearBufferArray function to clear the storaged data from the array
   count = 0;                       // set counter of while loop to zero
 if (Serial.available())            // if data is available on hardwareserial port ==> data is comming from PC or notebook
   GPRS.write(Serial.read());       // write it to the GPRS shield
void clearBufferArray()              // function to clear buffer array
 for (int i=0; i<count;i++)
   { buffer[i]=NULL;}                  // clear all index of array with command NULL
but compiling arduino says:
Code: Select all
sketch_nov19a.ino: In function ‘void loop()’:
sketch_nov19a:17: error: ‘class SoftwareSerial’ has no member named ‘available’
sketch_nov19a:19: error: ‘class SoftwareSerial’ has no member named ‘available’
sketch_nov19a:29: error: ‘class SoftwareSerial’ has no member named ‘write’
Here is the SoftwareSerial code:
SoftwareSerial: https://github.com/ZiTAL/arduino/tree/m ... wareSerial
jack
Re: Arduino GPRS Shield SIM900 not working by software
Post by jack »
the port 7 8 can not worked at software mode.
ZiTAL
Post by ZiTAL »
Software Serial Selected
Use D7 and D8 of the
Arduino to communicate
jack
Post by jack »
you shuld weld it like this
jafarin
Post by jafarin »
Old post, but I found it worth of nothing and I want to open questions why JP need to weld? That JP is used only for get D9 to working to start and shutdown GPRS Shield by arduino
Software Triger; If use this way to power up the GPRS Shield, JP need to be soldered, then Digital Pin 9 of the Arduino will act as Software Triger port and Digital Pin 9 can not be use as other purpose.
I have just same problem as Zital have. What wrong is with software mode in arduino or GPRS Shield v1.0?
Regards
Jafarin
techsupport
Post by techsupport »
Hi jafarin
Are the baud rate of GPRS communication and simulation of serial port communication rate consistent?
Email: forum@geeetech.com
jafarin
Post by jafarin »
It seems that baud rate of GSM shield v1 changing by it self or GSM shield cant keep it right. Next thread I told that I hunted baud rate to get OK from shield. Next time rate wasn't always same.
http://www.geeetech.com/forum/viewtopic ... 549#p20549
I must say that I am confused. Why GSM shield baud rate change by it self? If I dont get it work soon, I must make request to seller to get new shield or money.
jafarin
Post by jafarin »
I understand what you mean. Now I have hunted problem and software port D7/8 are between arduino and GSM shield. Serial port D0/1 are only used for debug.
With this code I found that some reason I have GSM shield where baud rate dont stay in same speed.
Code: Select all
SoftwareSerial SIM900(7, 8);
int workingSpeed=0;
void setup()
  Serial.begin(9600);
void loop()
   Serial.println("Testing GSM shield...");
   int speed[] = {2400,4800,9600,14400,19200,115200};
   if (workingSpeed==0) for (int i = 0; i < 5;i++)
      startGSMtest(speed[i]);
   while(true){};
void startGSMtest(int baud){
   SIM900.begin(baud);
   Serial.print(" start GSM speed ");
   Serial.print(baud);
   Serial.println(" baud");
   SIM900.println("AT");
   delay(1000);
   if (SIM900.available()) {
      while(SIM900.available())          // reading data into char array
            buffer[count++]=SIM900.read();     // writing data into array
        if (buffer[0]='O'){
           workingSpeed=baud;
Lemon
Post by Lemon »
jafarin wrote:I understand what you mean. Now I have hunted problem and software port D7/8 are between arduino and GSM shield. Serial port D0/1 are only used for debug.
Code: Select all
int workingSpeed=0;
void setup()
  Serial.begin(9600);
void loop()
   while(true){};
   SIM900.begin(baud);
   Serial.print(baud);
   delay(1000);
        if (buffer[0]='O'){
           workingSpeed=baud;
Dear friend,
According to your question, could you please be patient and try to test the items according to the following steps:
1. Confirm the baud rate.
2. Do you install the function library successfully?
3. When you use io port to simulate, is it appear some error message?
Waiting your reply. Best regards.
jafarin
Post by jafarin »
I found my problem. GSM Shield wasn't used fixed baud rate. It was set to use auto-baud rate and that's why it wasn't answer as I expected. Baud speed syncronate wasn't get up and I too fast expected that my shield was broken.
Code: Select all
AT+IPR=?
+IPR: (),(0,1200,2400,4800,9600,19200,38400,57600,115200)
OK
at
OK
AT+IPR?
+IPR: 0
OK
As you see shield baud rate is 0, what means autobaud. Thats why it is important to send AT-command, until shield give OK response. Then speed is sync and access is rdy. Also when auto-baud is used, some responses are missing. When I change baud speed to fixed, I start to get more responses, when I start shield.
Code: Select all
AT+ipr=19200
OK
AT+ipr?
+IPR: 19200
OK
NORMAL POWER DOWN
ÿÿÿÿÿÿÿÿ
RDY
+CFUN: 1
+CPIN: READY
Call Ready
Now my shield is rdy for rumble. :)
