acrylic I3 motor issues
buzmal
Re: acrylic I3 motor issues
Post by buzmal »
It appears that as the filament feeds in it feeds till the bottom of the nozzle then it seems to stop and form a plug at the end and seems to just squash down instead of extruding through the nozzle. some support would be nice
Admin
Post by Admin »
buzmal wrote:It appears that as the filament feeds in it feeds till the bottom of the nozzle then it seems to stop and form a plug at the end and seems to just squash down instead of extruding through the nozzle. some support would be nice
Is the teperature high enough?
Generally, it is 170-190 degrees for PLA, and 190-200 for ABS.
If necessary, you can raise it a bit higher.
buzmal
Post by buzmal »
i have tries raising the temp to 230 for PLA, it seems to help a bit but the same thing still happen after it flows for a while but then the motor still occasionally jitters.
zhangxueyou
Post by zhangxueyou »
Try to adjust the intensity of extruding by the thread.
buzmal
Post by buzmal »
I Have adjusted that screw. if it is lose then the gear slips after teh extruder blocks, if i tighten it the the motor jitters.
zhangxueyou
When you let the extruder work without filament, is the motor jittering?
buzmal
Post by buzmal »
No the motor runs smoothly it seems to just be that the extruded becomes blocked
zhangxueyou
If the extruder is blocked, please raise the temperature to 230 degrees, then try to extrude the filament with your hand downwards.
buzmal
Post by buzmal »
Ok so success!! i have got the system the print successfully. i had to turn the e step down to 100, it was feeding way to much plastic at 700, and up the temp to 230degrees
zhangxueyou
Great! Generally, the e step is 100. 700 is too high.
If the filament is PLA, 200 degrees is enough, or it may become black.
