acrylic I3 motor issues
buzmal
Re: acrylic I3 motor issues
Post by buzmal »
Ok I am still having extruder flow issues, in order to get the extruder to work at all i need to head the extruder to 230, my estep it set to 100, I am using 3mm pla.
The extruder will initally flow but blocks after a few minuets of printing an actual soloution would be good.
buzmal
Post by buzmal »
here is a picture of the latest print i tired, as you can see the print started but becomes stingy and lumpy and the extruder blocks causing the motor to pulse.
zhangxueyou
Post by zhangxueyou »
I am so sorry, I ignored something, If there is a big gear on the extruder, the Estep is 760, otherwise, the Estep is 95.
Please take a picture.
buzmal
Post by buzmal »
I have the mk8 I'll try turning the ester down from 100 to 95. If I manually extrude it works we and will extude smoothly.
zhangxueyou
Could you please take a picture?
buzmal
Post by buzmal »
I can what do you need a picture of the pic in the above post is of the printing results I have had on my last print. If you need a pic of something else I will post it when I get home.
zhangxueyou
I thought of my experience, which is similar to you.
There are two things you should do:
1. Check the Estep.
2. Check your slic3r settings.
buzmal
Post by buzmal »
What are the slicer setting I should be using for 3mm pla wih the .4mm nozzle
zhangxueyou
It is at the right side of Repetier: Tab"Slicer">the first "Configure".
buzmal
Post by buzmal »
Yes I know where that all is but what settings exactly am i supposed to be using.
