Printing Quality
abulafi
Printing Quality
Post by abulafi »
My printer is Acrylic Pro B and since I got it I am trying to reach similar quality as some of the parts your sent with printer (see the image below), but with no success.
What printer did you use to print these parts and with which material?
Acrylic Pro B.jpg (189.76 KiB) Viewed 14398 times
zhangxueyou
Re: Printing Quality
Post by zhangxueyou »
Hi,abulafi
We use Prusa i3 B to print these parts.
I think it's not the printer quality issue, it's because your slicer settings are not so good.
Please tell me you filament diameter and nozzle diameter, I can share my own settings with you.
abulafi
Post by abulafi »
Filament: 1.75mm ABS and PLA.
Nozzle: 0.3mm
zhangxueyou
Please download the attachment. Hope it will help you.
slicer settings(1.75-0.3).zip
(681.31 KiB) Downloaded 711 times
zhangxueyou
The part in you picture is printed with PLA
abulafi
Post by abulafi »
Thank you for information.
But these settings seems to be for ABS, isn't it?
I noticed that from the heatbed and nozzle temperature.
zhangxueyou
Actually , the main difference between ABS and PLA is temperature. Look at the picture:
3dnewb
Post by 3dnewb »
This helped me a ton thanks for the info!!
leonardo.galardi@gmail.com
Post by leonardo.galardi@gmail.com »
Using the setting you sent I had an enormous improvement. See the results :).
Do you have similar settings for 0.1 mm PLA?
Thank you
Leo
zhangxueyou
leonardo.galardi@gmail.com wrote:Using the setting you sent I had an enormous improvement. See the results :).
Thank you
Leo
Hi, Leo
Does "0.1mm PLA" means 0.1mm diameter nozzle, or 0.1mm diameter filament?
