I have brand new Mecreator printer that x axis doesn't work , to make long story short , I have changed the stepper controller and it works , my main issue is
when I print the part stretched on the x axis . Please send me the firmware ASAP as the buyer need his printer ASAP ( digitmakers@gmail.com)
and list for me what might be the root causes for the problem
Geeetech Mecreator printing issue
zhangxueyou
Re: Geeetech Mecreator printing issue
Do you mean that the model you print is longer than it should be on X axis?
digitmakers
Yes exactly it is double size on x axis
zhangxueyou
Do you use our firmware? If you use our firmware, did you modify something?
digitmakers
It is brand new printer, no one has touch the firmware .
when I set up the xaxis (from 80to 40 steps/mm) steps to half of the yaxis (80 steps/mm) it provide accurate print . By the way the stepper controller for the xaxis was not working I had extra one that I use .
Let me know what you think
zhangxueyou
Please check if all the jumper caps have been well plugged.
