i have installed the repetier software and can anyone give me proper setting i have to follow for below printer configuration ?
Acrylic Geeetech I3 pro B 3D Printer
Repetier-Host, windows 7
nozzle 0.3mm
Filament 1.75
ABS filament.
Best Regards
sabeel
Software Setup before print
zhangxueyou
Re: Software Setup before print
You can refer to the attachment. Though mine is not the best.
hi,
after applying the settings that you gave me it does not print well. it prints rectangle instead of square and prints out of the bed and it does not fill properly
i have attached the picture pls check and it printed well with default settings much better than this. what myt be causing this ?
- worst print :(
- 11121810_10152808880472986_1317790974_n.jpg (69.3 KiB) Viewed 9243 times
zhangxueyou
Is the model you are printing too big to print? If not, do you have firmware? I can tell you how to modify relevant parameters.
