Printer disconnecting
PseudoXenon
I have another problem with my printer, when i tell the printer to heat to a specific temperature it gets to the temperature, then it disconnects.
Does anyone have any ideas?
zhangxueyou
Re: Printer disconnecting
How do you tell the printer to heat, by LCD or Repetier on computer?
PseudoXenon
By using repetier on the computer
zhangxueyou
Which one is heating? Extruder or hotbed?
PseudoXenon
I am heating the extruder
zhangxueyou
When you are heating the hot bed or heating both hot bed and extruder, what will happen?
PseudoXenon
I dont use the hot bed, I am only heating the extruder
zhangxueyou
You can try Repetier Host 1.0.6.
PseudoXenon
I just updated and tried again and the same thing occurred
zhangxueyou
What is your printer type and mainboard type? Did you change the firmware?
