Printer dead? (Acrylic Geeetech I3 pro B)
Re: Printer dead? (Acrylic Geeetech I3 pro B)
The red light on the switch is on; no LEDS on the psu illuminated.
The red light on the switch is on, but no LEDs illuminated on the psu.
How do you connect the wire to PSU , is it like this:3d Printer Noob wrote:The red light on the switch is on, but no LEDs illuminated on the psu.
Yes. My psu looks a little different.
- 2015-04-11 02.23.09.jpg (515.43 KiB) Viewed 13081 times
Just a reminder: it was working once while testing heat bed and heat head (several feet of ABS was successfully produced). When I had an actual object to print, it died when I set the heat head to start warm-up.
When you turn on the printer, is this light on? Is the fan in PSU working?
No, the LED circled in the image is not illuminated, nor is the fan working.
Same issue for me
( power supply is dead prematurely !!)
It seems there is a REAL problem on power supply with Geeetech I3 pro B.
...Testing with an hold ATX power supply... and my pro B works fine !!
Same issue for me
I don't think so. Before we mass produced the PSU, we let the printer keep working with PSU for a week, and there is no any problem.elgroso wrote:Hi,
Same issue for me![]()
Can you take a picture of back side of the red switch?3d Printer Noob wrote:No, the LED circled in the image is not illuminated, nor is the fan working.
