I got my Extruder running but now it jumps cw to ccw
Mattao1977
I found the error in my firmware so I re installed it and my extruder is working but now it just goes clockwise to counterclockwise. What did I miss? I set the current at 1.45 like the X and Y. It only tries to feed when hot, which is normal I think.
zhangxueyou
Re: I got my Extruder running but now it jumps cw to ccw
Generally, the following reason may cause the phenomena you describe:
1. The temperture of extruder is not high enough.
2. The distance between nozzle and hot bed is too low the let the filament out.
3. The extruding intension is not high enough, rotate the screw on extruder to adjust it.
Mattao1977
Ok that didn't work, I heated the end up and removed the filament and it went cw to ccw, now it doesn't move again. Bad driver? The motor moves using another driver.
zhangxueyou
We are sure that it's not a bad driver, because we had every motor driver tested before sending to our customers. There are many reasons may shorten its life: Not cooling well, wrong connection, continuous working, static electricity,etc.
Mattao1977
Well I ordered 5 more, it will take 2 weeks to get to me but I will see if it is. Mean while I bought 10 bearings to replace the bad ones on the hot bed. I also bought another ramps 1.4 board because the one I got with the printer in the mail was damaged in shipping.
zhangxueyou
Please mount the board on acrylic plate like this, to make sure the fan can cool the MOSFET down. It is very important!
Mattao1977
I have 2 65mm fans cooling the board running off my computer, over heating isn't an issue but thanks for the warning.
- 0420151924_opt.jpg (61.8 KiB) Viewed 10226 times
Mattao1977
My printer finally works, after a month I ended up buying a new ramps 1.4 board, 5 new 8825 step drivers, new bearings and threaded rod. The extruder works and I got my first print today. So excited.
