Melted Geeetech Peek J-head V2.0 HotEnd
I've setup my prusa i3 and wanted to do extruder calibration with ABS filament, I heated hotend till 235 degree Celsius and feed it with ABS filament, filament traveled 33mm and stopped and than I checked my hotend and its heated metal part was moving when I touch cables. I researched on internet and saw lots of people had same problems with J-head hotend.
P.S. - I followed installation guide to the letter and Cooler fan of extruder was working while it melted.
So can you please give me OK for replacement ? And I will contact to customer service with this topic attached.
zhangxueyou
Re: Melted Geeetech Peek J-head V2.0 HotEnd
You can rotate the black screw hightlighted in the picture, to tighten the metal part.
black screw wont help my problem, because black part which is shown below is melted, please check the photo below.
- Melted hotend
- Melted.JPG (66.4 KiB) Viewed 12784 times
zhangxueyou
What is temperature set when you are printing?
Hello it was 235 degree Celsius for printing abs.
zhangxueyou
Did you change the firmware?
it's normal marlin firmware and its not problem of firmware because I've bought all metal hotend from my country and it works as it should but your product failed in first print while I was calibrating extruder. Can you please give me ok to refund or please send me all metal hotend. I received flawed products from you.
hello, I didn't change firmware and also i wrote another comment to this topic but it didn't published at all.
Please give me full refund or I'm going to open dispute.
zhangxueyou
Please contact the customer service to get a best solution.
Hi, i had the same problem just a few minutes before, did you recieve a good response??
