Y Axis Problem
3DPO
Re: Y Axis Problem
Post by 3DPO »
here it is
zhangxueyou
Re: Y Axis Problem
Post by zhangxueyou »
Oh, your board type is GT2560. There's no jumper cap.
Then you should check if the printing model is amplified on y direction.
3DPO
Re: Y Axis Problem
Post by 3DPO »
can you tell me how I do that?
3DPO
Re: Y Axis Problem
Post by 3DPO »
model always look regular in repetier host.
zhangxueyou
Re: Y Axis Problem
Look at the picture, but please make sure all the switches under A4988 are on. The picture you show me is Z motor.
And please make sure the red wire of fan should be connected to "+", otherwise the fan will be dead.
3DPO
Re: Y Axis Problem
Post by 3DPO »
all the switches are on and the fan is plugged in. Please see the attached gcode and photo, scale of everything is set to 1. I did try setting the Y-axis to 0.25 which brought the print close to correct size. Can you tell me how to fix this?
zhangxueyou
Re: Y Axis Problem
Sorry, but you forgot to upload the g-code file. If you can not upload, you should add it into a zip.
3DPO
Re: Y Axis Problem
Post by 3DPO »
here it is
gcode.zip
(218.4 KiB) Downloaded 395 times
zhangxueyou
Re: Y Axis Problem
Please tell me the values of "X-steps/mm" "Y-steps/mm" and "Z-steps/mm" on LCD:
Control>Motion>Y-steps/mm
3DPO
Re: Y Axis Problem
Post by 3DPO »
see photo
