LCD 2004 Garbage on
4x6hp
LCD 2004 Garbage on
Post by 4x6hp »
After first power on, just assembled geeetech prusa i3 printer, on the LCD I see strange characters. Look at the pictures attached. Double checked all solder pins on LCD PCB and on cable adapter, no problems found.
Can some body to advice?
zhangxueyou
Re: LCD 2004 Garbage on
Post by zhangxueyou »
How about swapping the connection of 2 cables?
4x6hp
Post by 4x6hp »
The cable swaping did not help.
The problem was, wrong LCD type selection while upload firmware.
The problem solved by reloading firmware and defing #define REPRAP_DISCOUNT_SMART_CONTROLLER
johnz
Post by johnz »
Can you show how you got it to work..step by step ..total newb here??
