After first power on, just assembled geeetech prusa i3 printer, on the LCD I see strange characters. Look at the pictures attached. Double checked all solder pins on LCD PCB and on cable adapter, no problems found.
Can some body to advice?
LCD 2004 Garbage on
LCD 2004 Garbage on
- 5_IMG_20150515_151058.jpg (43.71 KiB) Viewed 11426 times
- 4_IMG_20150515_151047.jpg (38.68 KiB) Viewed 11426 times
- 3_IMG_20150515_151014.jpg (59.74 KiB) Viewed 11426 times
- 2_IMG_20150515_135018.jpg (47.59 KiB) Viewed 11426 times
- 1_IMG_20150515_022837.jpg (33.26 KiB) Viewed 11426 times
zhangxueyou
Re: LCD 2004 Garbage on
How about swapping the connection of 2 cables?
The cable swaping did not help.
The problem was, wrong LCD type selection while upload firmware.
The problem solved by reloading firmware and defing #define REPRAP_DISCOUNT_SMART_CONTROLLER
Can you show how you got it to work..step by step ..total newb here??
