Mosfet problem
Mosfet problem
geeetech-official,
hello
I put everything as how to explain the manual and following the configuration website geetech wiki, but at the time of giving the temperature at the heated plate has happened this as shown in the attached picture, the integrated tends to overheat and ruin everything, what You can do?
let me know.
thanks to early
- pgioy
hello
let me know.
thanks to early
- pgioy
- Mosfet
- image.jpg (98.15 KiB) Viewed 12946 times
zhangxueyou
Re: Mosfet problem
How did you mount the mainboard to Acrylic plate?
Re: Mosfet problem
hello I just dismounted to see what has happened, I attacked on quell'innesto Heatbed as described in the manual, the problem is when I agree to give the temperature Heatbed, the MOSFET overheats the others are ok remain cool, I think that component is defective. for everything else works. hello thanks
zhangxueyou
Re: Mosfet problem
What is the resistance of heat bed?
Re: Mosfet problem
the resistance of heat bed is 1k, to see attachment
- image.jpg (43.84 KiB) Viewed 12930 times
zhangxueyou
Re: Mosfet problem
1k ?! That's impossible. Normally it should be 1.2 ohm. How did you test the resistance? You can test the resistance at the 2 ends of hot bed wires.
Re: Mosfet problem
I tested with my digital multimeter and reading me the value of 1k
zhangxueyou
Re: Mosfet problem
How did you test the resistance of hot bed?
Re: Mosfet problem
ok, I just tested as photos and the value is between 0.45 and 0.60
zhangxueyou
Re: Mosfet problem
That's abnormal with current double.
