Mosfet problem
Re: Mosfet problem
I did another test, just connect the warm bed that mosfet gets hot, cools and unplugging the printer works but are not flat.
Re: Mosfet problem
Can you move the motors and heat up the extruder? If they works fine, you need to replace a new MOSFET only.
Re: Mosfet problem
is their work without problems the temperature of the 'extruder rises above 200 degrees without problems
Re: Mosfet problem
The current for heating extruder is lower than the hot bed, so I think it's ok.
Re: Mosfet problem
I guess the problem is that the MOSFET or a general problem on the board but that is not seen.
Re: Mosfet problem
So we need to check if the other part of the board is fine. If they are fine, then replace a new MOSFET, and check if the MOSFET is still burnt.
Re: Mosfet problem
I confirmed that I do replacement mosfet, and if the problem persists you change the card?
Re: Mosfet problem
That's the only way to solve the problem if it persists after you replace a new MOSFET.
Re: Mosfet problem
hello, I did change the mosfet again as seen in photos but the problem persists, he continues to overheat and burn all around.
- image.jpg (183.79 KiB) Viewed 10765 times
