Extruder is not heat up
sayanc
Post by sayanc »
The extruder is not heat up to set point 180 degree , it is still 36 -38 degree. The bed temperature is ok. Please advise. Thank you
Sherry
Re: Extruder is not heat up
Post by Sherry »
Maybe the wire of thermistor of extruder2 is not being connected well. You check if the line of thermistor is loose.
sayanc
Post by sayanc »
Dear Sir,
I checked the connection, it is good but I checked ohm of the extrude heater ,it is broken ( it doesn't have resistance compare with the bed heater, it is good). How can I change the heater and where can I buy (I have just try to inject in the first time).
Thank you
check ohm of the extruder heater
Sherry
Post by Sherry »
i think the heater strip was burned out,you had better to replace a new heater strip.
sayanc
Post by sayanc »
How is to take out?
Sherry
Post by Sherry »
look at the picture. There are 2 small screw in good packing heater.Using hexagonal socket nut to loose the screw(look at picture 3).And then you could take out the heater strip.
picture1:packing heater
packing heater.jpg (36.53 KiB) Viewed 10049 times
picture2:hexagonal soket
hexagonal soket.jpg (74.32 KiB) Viewed 10049 times
picture3:heater
picture3:heater
extruder heater.jpg (40.17 KiB) Viewed 10049 times
sayanc
Post by sayanc »
I changed the heater already and it is ok. Now the temperature of bed and extruder are ok but I do not understand, how to insert or setting the filament. I try to test slic3r file the movement of motor x,y,z and extruder are ok but it is not pla filament injected to the bed. Can you explain how to insert the filament or how to setup the extruder, please?
Thank you and best regards,
Sayan
