Motors on extruder doesn't work
Sherry
Re: Motors on extruder doesn't work
Post by Sherry »
hi,sogi.please tele me the following infomation.
1.what type of the control board you use now.
2.maybe the extruder slot is reversed.please take some picture and let me check.
3.Did you reburn the firmware?
sogi
Post by sogi »
This is my old board
And this is my new board
I was upload the firmware that you send me.
Externally board is different location of the ports of endstop of axes. On the old board they installed parallel to ports of motors, on the new board they installed perpendicular to ports of motors.
sogi
Post by sogi »
Hello. I didn't hear anything from you two days. What I need to do? Can I to modify something in the firmware?
Sherry
Post by Sherry »
sogi wrote:Hello. I didn't hear anything from you two days. What I need to do? Can I to modify something in the firmware?
hi,please read this post.maybe it will help you solve the problem.
http://www.geeetech.com/forum/viewtopic ... 19&t=16637
sogi
Post by sogi »
It doesn't resolve my problem. The motors are ejects filament up.
Sherry
Post by Sherry »
sogi wrote:It doesn't resolve my problem. The motors are ejects filament up.
there could be some errors in the firmware,what's your printer type? i will tell you how to modify the firmware.thx
Jeepfrog
Post by Jeepfrog »
i am having the same problem i have the G2s
Mark
Post by Mark »
帖子由 sogi » 周五 7月 17, 2015 4:10 pm
Hi, you should change the corresponding motor direction in the configuration.h tab in your firmware:
#define INVERT_X_DIR true // for Mendel set to false, for Orca setto true
#define INVERT_Y_DIR false // for Mendel set to true, for Orca set tofalse
#define INVERT_Z_DIR true // for Mendel set to false, for Orca setto true
#define INVERT_E0_DIR false // for direct drive extruder v9 set to true,for geared extruder set to false
#define INVERT_E1_DIR false // for direct drive extruder v9 set to true,for geared extruder set to false
#define INVERT_E2_DIR false // for direct drive extruder v9 set to true,for geared extruder set to false
#define INVERT_E3_DIR false // for direct drive extruder v9 set to true,for geared extruder set to false
