Delta Rostock mini G2 - carriage
DigitalJax
I have assembled an delta mini, the carriages are cold printed and all three have structural issues. The first two have broken as soon as the servos move the first time . the third has cracks in the layers in the same place. If you can send me the STL files I will pay to have them reprinted. I would also like the spider stl's also to recreate them in metal. Many thanks
- carriage
- IMAG0094.jpg (60.2 KiB) Viewed 13225 times
- carriage
- Car02.jpg (29.43 KiB) Viewed 13225 times
- Spider
- Car01.jpg (42.54 KiB) Viewed 13225 times
Re: Delta Rostock mini G2 - carriage
Hi,the stl files of delta rostock mini are in the attachment.if any one ask for the stl file of geeetech printer,please goes to the following link.thx!
http://www.geeetech.com/forum/viewtopic ... 24&t=16616
- delta rostock mini.zip
- (426.02 KiB) Downloaded 661 times
fotomickey
Hi experts here,
I have issues assembling spider to ball joint, the m3 washer (bag#5) seem too small only 5mm diameters from the package !? It didn't seem to able to hold the rod-end bearing holder in place. Do you folks experience same problem ? Any advise ?
Thanks in advance
Thanks in advance
you could purchase those m3 washer of which diameter is 7mm in your coumtry.it's very cheap.fotomickey wrote:Hi experts here,
Thanks in advance
fotomickey
Thanks Eric, look like need to redo all "82"the washer.cycle
fotomickey
Hi all expexts
Checked 2 local electronic parts store, it is not common to find 7mm diameters m3 washer in vancouver. Not sure why Geeetech not just included 7mm m3 washers to avoid troubling customers . Anyway also found smooth rod too loose and whole frame will wobbling after assemble. Not sure how to fix this one. Please provide more advise.
Thanks in advance
Thanks in advance
hi,you could buy it on the internet.could you leave your order number,i will help you contact salesman.thxfotomickey wrote:Hi all expexts
Thanks in advance
I had the same problem with the small M3 washers. Not sure if you have a Home Depot in Canada, but they have them. You could also try stacking an M3 on an M4.
