motors extruder not working
harmas
Post by harmas »
I bought a Prusa i3 C all is well except that the driver of extrude blocks each time printing starts .I pushed by the hand he normally walks the temperature extrude 240 bed 95 help me please with picture
Sherry
Re: motors extruder not working
Post by Sherry »
harmas wrote:I bought a Prusa i3 C all is well except that the driver of extrude blocks each time printing starts .I pushed by the hand he normally walks the temperature extrude 240 bed 95 help me please with picture
hi,please try the following steps to trouble shooting.
1.please swap the driver board with x-axis,if x-axis is working,the driver board is good.
2.please connnect the motor wire of the extruder to x-axis .if working,the stepper motor is good.
3.please reburn the firmware.
harmas
Post by harmas »
thank you for your reply
5 days and there's nothing
the motor of the extruder well tourn
reburn the firmware ??! I do not know how
all okay except that the filamnet does not automatically spell ..with hand it out
temperature 240
bed temperature 95
GT2560
ABS filament B !!
MK8 extrude
please ..
I am debutant sent me the file slic3r configuration Prusa i3 pro c 0.3 mm nozzle with photos sp
the calibration file photo please please: I extruded 100mm but the motor only 15 mm extruded and blocks
sent me all the detailed
Sherry
Post by Sherry »
hi,i've sent related files to your mailbox.please try to reburn firmware firstly.
harmas
Post by harmas »
when printing: FILAMENT
pushed with the hand it passes very well and prints
without hand he does not pass .... but the motor turns slowly
0.3 mm nozzle is clear is not blocked .. what is the problemeeeeee ????
I have the ABS filament B send me the file for this filament jenre 1.75 mm
send me please the calibration file
What is the ideal configuration EEPROM? PRUSA I3 PRO C. I have not changed anything in the distance from the nozzle relative al extrudeure
give me the configuration Standard eeprom ..the calibration file please
My E-steps: 95 mm is normal ? IT IS ENOUGH? WITH pic please
Sherry
Post by Sherry »
do you set up feet rate?Normally,the feed rate is 100.
harmas
Post by harmas »
yes my feet rateis 100
send me your mail please
I send you
my video that explains the problem please look and help me
