Hi, I've just received the board+iduino due from an ebay reseller.
Unfortunately, the board version is the 1a; I have try the board with a porting of Marlin firmware but there are many problems:
-random disconnection from repetier-host
-only X min endstop work
-when I start the print, the movements are uncontrolled and stop after few seconds
Can be a problem of the board? firmware? else?
My system is based on windows 7 x64 with repetier-host 1.0.6
Thanks.
Ramps-FD v1a
zhangxueyou
Re: Ramps-FD v1a
Please check if the status of endstops are correct in firmware.
saviothecnic
Re: Ramps-FD v1a
Also I'm having a lot of problems with this card
For switches I solved it seems that the word min max is reversed
It must be enabled by FW resistance PollUP
I have a big problem I go thermistors are 100k
Ramps on 1.4 work on ramps FD-1a I always read 140 ° C
Re: Ramps-FD v1a
Hi,saviothecnic.
I think your firmware is the wrong edition,can you tell me what your printer type is and your mainboard ,see I could find the right firmware for you.
saviothecnic
Re: Ramps-FD v1a
I have a card-FD Ramps v1a with ArduinoDUE
Printer type Cartesian type Prusa I3
FW Used Marlin4Due portring Kimba http://marlinkimbra.it/
I also tried RepiterFirmware
but I prefer to Marlin
I include photos of my current installation
Thank you
Thank you
- RampsFDv1a_Marlin.jpg (44.21 KiB) Viewed 11549 times
Re: Ramps-FD v1a
sorry,I do not have the firmware you want...
saviothecnic
Re: Ramps-FD v1a
You can attach what you are using now?
so I check if loaded on my card works all
and especially the temperature sensor
