offset nozzle bed creator mini
clint6wood
Post by clint6wood »
hello, I have mini creator . it works well but not print to bed center
I should be able to make objects 150mm X, Y but the nozzle out of bed ...
how can I solve this problem ?
Thank you
Mark
Re: offset nozzle bed creator mini
Post by Mark »
Sometimes is the software problem of slic, you can try create another slice document to print it;
Or maybe try scale down the model a little to print a small one , and see if there is the same problem.
clint6wood
ok but it does not solve my problem.
I am a maximum print an object of 140mn x, y,
normally described as Me creator can print 150, 150, 150mn
how I can pay my bed with my nozzle to finally print a 140mn object :cry:
clint6wood
ok but it does not help me too much.
print desired minimum 140mm x, y and Me Creator is that it can do in theory 150 x, y ...
help me please you
Mark
Post by Mark »
Did you set the correct settings?
slic settings.jpg (288.79 KiB) Viewed 12333 times
clint6wood
hi Mark , I set as on your screenshot .
the nozzle no longer out of bed but is still not centered resulting object is cut it is not printed entirely ...
the creator mini, when the nozzle is at home she is out of bed ...
repetier in the small circle indicates the nozzle ?
Thank you
Mark
Post by Mark »
can you show me a pic about this?
clint6wood
Well, I reinstalled my repetier object is centered in the software but not on the bed
I tried to play on the left and rear kidney shift happens
view screenshot
Mark
Post by Mark »
Try to adjust the settings in here :
clint6wood
thank you , I'll try and come back to tell the result .
