Hello Folks,
after a long hiatus, I am back in action. I just installed the new firmware for my Prusa I3 Pro C, and the Extruders still cannot be turned.
My test sequence is:
a) Preheat ABS, wait until heat is reached
b) Move Axis -> Extruder -> turn pot, at which point nothing happens
Strangely, the printer operating software offers only one Extruder in the Move Axis option, while it offers two in the heatup menu and also welcomes me to a Prusa I3 C correctly.
Prusa Pro I3 C - Extruders still dont work
Re: Prusa Pro I3 C - Extruders still dont work
Where did you get the firmware? The old verdion has a problem that can cause this, try to burn the attached firmware here.
- Marlin_GT2560-PI3_Pro_C.zip
- (299.21 KiB) Downloaded 411 times
I took it from the sticky thread. Weirdly, the extruders can be turned from Repetier...this seems to be an issue of the LCD only!
Tam
Tam
Do have some pictures about this?
"the extruders can be turned from Repetier" Can you control other parts of the printer by LCD, or just can not control the extruders?
yes - the axis can be controled from both LCD and Repetier.
The Extruder can be commanded only from Repetier.
Did you choose the option move 10mm? I remember this option does not work for extruder but only for X,Y and Z axis.
no, for me, neither of them worked.
Tam
Tam
Can you show some pics about the LCD for me?
"the axis can be controled from both LCD and Repetier.The Extruder can be commanded only from Repetier.'
When I choose move 10mm, there is no extruer for me too.see the pic below:
- QQ截图20150909162144.jpg (67.9 KiB) Viewed 9919 times
- QQ截图20150909162135.jpg (98.63 KiB) Viewed 9919 times
