Arduino 1.0.1 Not Showing Sanguinololu as Board
Khilborn
Post by Khilborn »
I have downloaded the Aurduino and need to burn the firmware but Sanguinololu is not showing up in the list of Boards??????
Mark
Re: Arduino 1.0.1 Not Showing Sanguinololu as Board
Post by Mark »
Did you install the driver?
Khilborn
Post by Khilborn »
Yes, we had all this working fine until you guys sent me a new hotend, now the printer prints like garbage so we are redoing all calibrations.
Mark
Post by Mark »
Did the PC recognise the COM port or not?
Khilborn
Post by Khilborn »
Yes, All we did was change out the Hot End that you guys replaced. The printer was printing pretty flawlessly before we switched it out. Now it's printing like garbage.
Mark
Post by Mark »
How about the later version of arduino ?
Khilborn
Post by Khilborn »
What would the latest version of audrino do for me. The problem we are having now is this.
After putting on a new hot end the E step do not seem dictate the rate at which the filament goes through. The original firmware E step (before the new hot end) settings were set to 95. When using that setting and extruding 100 mm the filament only measured that it extruded 27 mm. I tried doubling the E steps in the firmware and I could see the motor turning faster but the same amount of filament was extruded. Any suggestions will be appreciated.
The printer was printing perfect until the hot end went. All we did was put a new hot end on.
Mark
Post by Mark »
weird! how about changing it back?
Khilborn
Post by Khilborn »
Can't put it back because it caught on fire......
Mark
Post by Mark »
If you remove the giude tube, and do not plug the filament into the hotend, manually extrude 100mm, how about the actual extrude length?
And check the driver subdivision of the extruder see if they are correct.
