geeetech prusa I3 x extruder not heating up
I have a prusa I3 x and i cannot get the extruder to heat up. It doesnt go past 32 degrees celcius.
Re: geeetech prusa I3 x extruder not heating up
hi,please see if those three red toward heating cable connector leds are lighted up or not.
Manually heat up the hotbed and extruders, if the LED lights under the hotbed and extruder slot are lighted up, then the mosfet that controls the heating is good. next,please measure the resistance of two end of heating cable,it's resistance is about 3.6 ohms.
computer board
- no red leds?
- 20151001_130952.jpg (376.29 KiB) Viewed 9673 times
i dont see any red leds lighting up and i have 3.3 ohms across the heating cables. before i was able to manually heat the hotbed up but not the extruder. now neither will do anything.
- lcd reading error mintemp
- 20151002_111158.jpg (136.51 KiB) Viewed 9673 times
- computer board
hi, there's two places to check:
1) you have connected the extruder heating wire to the wrong place, it should be the first one;
2) the thermistor of the extruder1 is open circuit, please check the wires, see if not correct connected
- QQ截图20151003210618.png (187.42 KiB) Viewed 9668 times
- QQ截图20151003210346.png (482.46 KiB) Viewed 9668 times
