could you please send me the firmware for my Geetech Mendel Prusa I3 8mm Acrylic with .3mm nozzle?
I have a hard time finding the right steps per mm for all axis.
Thanks (in advance) for your help.
Firmware request Prusa Mendel I3 with MK8 Extruder
daniel_bauer
Re: Firmware request Prusa Mendel I3 with MK8 Extruder
Is your printer type is I3 pro B or pro? and what's the board type?
daniel_bauer
It says geetech i3 at the top. And above the text there is a 2004 LCD screwed to the printer.
The controllerboard is a white GT.
Ok , I'll give you the firmware for I3 pro/pro B of GT2560, you can try it.
- Marlin-PI3_Pro_B.zip
- (299.21 KiB) Downloaded 645 times
Juan_David
Hi Mark,
I upload this firmware, but now I can't actualice the firmware and EasyPrint3D program show a window that said unknown device.
And the extruder flow isn't enough, the filament extruded is so thiny
How I can solve this issue?
There are some wrong in the extruder, specifically in the screw that pushes the filament which slides when pushing plastic because it does not have enough pressure.
The solution was as easy as putting a piece of paper in the extruder's spring, so that it becomes stronger and the filament does not slip when it passes through the screw.
- 出料不够改进图.jpg (485.25 KiB) Viewed 8870 times
