I have a problem with my x axis on my Me Creator moving only in one direction. I tried the following using the Repetier Host V1.5.6:
X Axis
X Axis endstop: Tried M119, found to be triggered and traced it to a disconnected lead (Fixed)
Y Axis
The Y axis movement stops in the middle of the printer. Does not seem to move beyond a set point of the machine.
Can you advise me as to how to resolve the problem?
X Axis moving only in one direction
Re: X Axis moving only in one direction
the Y axis, is your printer settings correct?
- QQ截图20151116180349.jpg (147.12 KiB) Viewed 6579 times
brisrascal
Isn't the heatbed 150 by 150? I have addressed the Y axis problem which is due to a disconnected endstop.
If your printer is prusa I3, then I remember it is 200*200.
